A TRUE WISH FOR CHARGING
mcm4ss
Bend, Or.
Full EV. no worries. Don't need range extender hardly at all to be honest. The ability to strap down a generator in the bed, or on a rack and charge while driving. My choice of generator. My ability to remove when not needed. Just something to help with those really long trips I take 2-3 times a year. Not having to stop for a couple hrs to charge because I could while moving would be amazing. Just a thought.
Howard
Howard
Fort Wayne
Scout II, Maverick, Escape
Sounds good in theory.
But do you have any idea of the generator size needed to produce significant range extension? Given that a level 1 home charger running off of 110v will give about 5 mi. of range from a hours charge, you're going to need something you're not going to strap to your roof rack.
I wonder just what the size of the Harvester generator will be?
mcm4ss
mcm4ss
Bend, Or.
I got a 9K for the CT when I go hunting for those rare cases. Used it once. Took about 2 hrs total stoping. Lunch, scouting, ect. Worked great. Just saying that I would bet 90% want the extender for piece of mind over actual need. In my case there is no electricity out there at all and it is always about 50 miles I need extra. Just a thought. Not get rid of the Harvester, just give the EV side that option to charge while driving maybe.
Howard
Howard
Fort Wayne
Sounds like it's more than a wish for you. You're all set.
The Harvester genset head will be in the 100-130KW range, A generator that size will need it's own trailer to haul. A 10K genset weighing in @ around 150-200 lbs will be a chore to lift, but would get you charged up in a couple hours. But it would use as much gas as the Harvester, take up bed space, be louder and much less convenient to use.
More likely, about half that size.
I read somewhere it was about 130, but thought that was to large, to maintain full capabilities and roadability as stated it would have to be at least 80KW
mcm4ss
mcm4ss
Bend, Or.
not after full capabilities. the ability to to just add a bit. take out when not needed. After the interview, would also give us back the towing and weight capability. Sometimes an extra 20 miles is all it takes.
Peter
Tesla Model 3, Ford F150
I thought that somewhere it was mentioned that the Harvester is a 1.6 liter VW 4cyn engine. That's pretty big. Again, not sure...
That's what it is speculated at being. The details for the generator have not yet been released.
I have serious doubts the Scout Harvester will be nearly that large. A lot depends on the target market - and for a startup, that should be a mass target market. Only a small fraction of the market tows, and even that fraction does not tow regularly or long distance. It is just not a great target for a companies first steps out of the gate.
The Dodge Ramcharger was spec'ed with a 6cyl 130kw generator. Most of the EV truck reviews I have read have shown 140-160wkh batteries giving about 1.5hrs of range with a 10k load (and no discussion of how aerodynamic that trailer was). On the flip side, when not towing 2 miles/kw seems realistic for an EV truck not towing - so a generator slightly below 40kw would work. For best efficiency for most people the vast majority of the time - it is simply a better target. 40kw could be handled by a 70hp motor. Easy enough with a normally aspirated 4cyl motor.
